Vibration
Barry J
Car: 2009 Nissan Rogue
On our Rogue, sometimes when we go over 40-50 mph the front end vibrates. This happened twice, once a couple of weeks ago, and we thought it was just snow build't up in the wheel wells. But, today it was 50 degrees and my wife went to the car wash and sprayed off the car and it started to do it again.
Any suggestions??
thanks
Barry
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
I would guess that this is a tire that requires balancing, a very simple and routine fix. It could also potentially be an issue with the front end such as alignment, in which case you would notice the car wandering to the left or right, or it could conceivably be a bad wheel bearing.
Those are the first things that come to mind, I'd start by taking it to the shop and they'll most likely check the balance on the tires and check for uneven tread wear first as the most likely culprit.
Good luck and let us know what you find out!
Return to “Rogue Forum”
