clawsj01 »
https://forums.nicoclub.com/clawsj01-u174932.html
Fri Dec 24, 2010 1:35 pm
I'm getting a vibration in my 2000 qx4. Its most noticeable from 50 to 60. 145k miles on it. I'm going to look at it this weekend Think it may be the rear diff going out? Any ideas or common problems areas I should check?..
Edit...
the vibration can be felt in the seat.. I had it up on the lift tonight and found major noise/vibration from the rear diff.. very disapointed. looks like the rear end needs rebuilding at only 145k? I have run synthetic in it for some time now.. I also have some play in the t-case output shafts..after some search on this forum that seems normal.. has anyone had experience with either of these problems??
Thanks,
clawsj01 on Fri Dec 24, 2010 10:51 pm, edited 1 time in total.
