vibration?
Popsickle
Car: 2006 M45 Sport
I just had all my rims repaired, balanced, new tires, and new rotors. But between 70-85mph the car still vibrates at an alarming rate (I literally wouldn't go over 60). Even at lower speeds you can see items in my car constantly shaking. What should I do now... alignment, a better set of tires? Has there been any known problems with the suspension? At times the car feels extremely bouncy even when the road has no dips, then within the same trip it feels pretty stiff and loud. Other times it will go from stiff to bouncy even on routes where it was the other way around. Sorry if it sounds confusing, I had to take some medication
Thanks, Sickler
szh
Car: 2018 Tesla Model 3.
What tires are you using? How old are they?
Z
M35 Sport
Car: Infiniti M35 Sport
Well the only thing I can suggest is that maybe your tires need to be road force balanced. And if that does not help you could have a bad drive shaft.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Popsickle wrote:I just had all my rims repaired
Why and how? Your wheels may have lost a stick on weight. Depending on the original condition of your wheels, you may have excessive lateral runout that standard dynamic balance will not detect. The M45 wheels tend to irrepairably bend easily and having them stripped and resprayed does very little for correct a dent.
I would also recommend a road force balance if done correctly this will tell you what the cause of your vibration is.
