vibration?
saeedakobiakov
Car: 03 M45
Hello,i got 03 m45 and i noticed light vibration during moderate acceleration between 50 to 60mph. after it hits 60 it's just goes away. Please tell me why?Thanks,Caug
szh
Car: 2018 Tesla Model 3.
saeedakobiakov wrote:Hello,i got 03 m45 and i noticed light vibration during moderate acceleration between 50 to 60mph. after it hits 60 it's just goes away. Please tell me why?Thanks,Caug
Could be a variety of things, any comment I make is a SWAG.
My guesses would be:
Unbalanced tires. Another possibility is "silent" pinging due to bad or low octane gas, that is manifesting itself as vibration. Or wheel-bearings.
Worst case, you have a driveshaft or shaft bearings problem. But, this I would doubt, since you have not had the car that long.
Please let us know what you figure out ...
Z
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Z is right both of those things will cause a harmonic vibration at a certain frequency.
Something like a miss might cause that although that would more than likely cause a CEL to set.
If you let off the accelerator does the vibration go away?
Does the vibration continue when you are coasting at ~60 mph?
grindjv
I had this sort of thing, and a rotate and balance straightened out the problem
saeedakobiakov
Car: 03 M45
bad gas is out, i use shell v power octane or sunocco brands.i will balance tires and we will see.Thanks for your inputs.caug
