darbysan wrote:Also had local shop check out the driveshaft alignment. They thought it was out ( from transmission repair) but changing it did not affect the vibration. They even tried a couple of orientations with no success.
It sounds like you've been Searching, so I assume you've run across the problems with fiddling with the "guibo"?
Sounds like you're describing the guibos at the very tip of the driveshaft... I have plenty of them at home but they are worth a damn since once removed from the shaft, they lose balance. Thats why many times you see paint on the bolts as a marker. The service manual actually tells you not to mess with em.
zerothread?id=249209
zerothread?id=276940
Read Drew's posts on this thread:
zerothread?id=259947
and here:
Driveshaft vibration is not constant. At very slow speeds you'd never know. When mine went bad, it vibed in the 35-55 mph range, then again and roughly 80-90 mph. This is commonly seen.
zerothread?id=237244
If you've already read these threads, my apologies, but it will be helpful for future Searchers
Also, that bent wheel ... you ruled it out ... how?
The transmission mount and exhaust hangers won't cause the vibration bands you're talking about. So ... it sure sounds like something in the driveshaft assembly.
