Vibration noise when backing up
ADF932
Car: S13
Almost every time i back up or the car roll backs i hear a nasty vibration sound that comes from the rear of the car and i cant really figure out where its coming from??????? I need help finding out where this problem is coming from. Thanks
Dukki
could be a seized caliper or calipers.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Brake pads may be excessively worn causing the brake wear indicator to scratch the rotor.
rotorimp
Car: 02 Xterra, 60 IH Metro
Could be the drive shaft? check that the carrier bearing and joints are all ok. Could also be time for a diff fluid change (see if anything comes out).
topairhead
Car: 180sx
i have a 91 240sx hicas and does the same thing i always thought it would of been becaz of the hicas but many could be the brakes since i do need brakes in my car?
duty780
Car: 1993 vert.. sr
I know this thread is old. but we are here for each other right
I have the same problem in mine, and i have new rotors and pads, so is no the brakes, although the problem began about 2 days after my brake job. it occurs on my passenger side rear tire. the whole tire kinda jumps and everything, as i had my friend back it up for me, but is really hard to knowist what is causing it.
Nick240sx
Car: 2009 Ford Fusion SE Sport
you guys have to stop running over smurfs
blinkshome
Car: 95 240 ka24det
mine did the same. where the axle goes into the wheel hub theres a very tight tolerance. for some reason mine rubbed there only in reverse or when the car went backwards. i shot some silicone in there and it instantly cured the problem. i did this about three times in a month and never heard the noise again . hope that helps.
okinawa drift
Car: 89 240sx SOHCoupe
Nick240sx wrote:you guys have to stop running over smurfs
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I have the same problem. The noise had always occured, but really started to become more frequent after I changed all rotors and pads. What's funny is that when the noise is occuring, after I tap the brakes while still backing up, the noise goes away.
elks 240
Car: 93 240
OK, remove your rear brake caliper, there are 2 little pistons that the bolts go through to bolt up the caliper. Now pull those apart and clean them very well with brake parts cleaner, and maybe a very fine sandpaper. Main thing is get rid of the coked up grease in there. Make sure it moves in and out smoothly when you are finished removing the old grease. Re grease these and on most of you guy's cars that is having this issue, will go away.
Thoughtful_One
2000 Honda Insight
Are you talking about the sliding pins? The ones that are covered by the rubber boot? If so, I made sure to apply anti-seize to them before I put everything together.
