oz240red »
https://forums.nicoclub.com/oz240red-u97606.html
Mon Mar 16, 2009 1:44 pm
Let me describe the symptoms and what was done, and you give me your opinion
1- Changed the clutch to a performance clutch from Competition Clutch, had my flywheel resurfaced.
2- Changed the motor mounts (bought them at ebay, they are "Toki Rubber" brand... don't be a wise @$$ and tell me that's my problem lol). They fitted perfect, but look more sturdy and fell way more solid. Of course, the original ones are 120k miles old.
Symptoms:
1- You can feel a real fast vibration on the steering wheel and parts of the interior rattle.2- The cabin is noisier3- The vibration seems to be constant throughout the rpm range.
First thing that came to mind: "@#$!#@$% the flywheel wasn't cut right and it's out of balance!", but then I started to second guess myself because I've never had mounts so stiff on my car. Before I used to be able to rock the engine from side to side easily, but now I can't move it even a quarter inch. These mounts are really stiff....
Any other suggestions on how to tell if the vibrations come from the flywheel? (note: it does it while in neutral, so I don't think it's the drive shaft)
thanks
