nuQ »
https://forums.nicoclub.com/nuq-u4532.html
Sun Nov 07, 2010 10:46 am
I'm not sure......the power steering fluid is fine, and tires balanced (which, of course, would be a non-issue at idle), but the problem still persists. My plan is to get it on a lift this week, and check below and work up. I want to see if the motor/trans mounts are ok, check to see if there are no further exhaust leaks (it does sound a little loud), or any other issues from the front end.
Another question I would ask is; can a seized up pulley bearing cause a noticable shudder at idle and speed? Before I parked the Q years ago I was thinking about replacing the pulleys because they would squeal under excelleration. There is a noticable squeal when I start the car and when turning the wheel at low speeds. Just a thought....
And I guess to elaborate on what you wrote Heath, it is more of a "shudder" at idle and when excellerating,,,not so much at a cruising speed. I suppose a vibration would be more of a very quick sequence, where a "shudder" (like what is happening now) is almost like feeling the engine "rumbling" with the car "shacking".....can be felt all over while sitting in the seat,,not just the steering wheel...If that helps describe things a little better. Thanks
