Vibration in the brake pedal
Versagirlie
Car: 2008 Nissan Versa 1.8SL CVT Hatchback
I got my oil changed yesterday for the 15000 mile mark, and now when the car is at a complete stop there is a vibration in the brake pedal, but only when the car is in drive. Anyone else had this propblem? I'm calling the service dept tomorrow to make an appt
AG
ABS?
CodeRed
Car: 2008 Nissan Versa S MT
AG wrote:ABS?
ABS is like VETCH, it only kicks in when you punch the pedal hard.
Versagirlie
no ABS no fast stopping at all. Its just really odd
pfc369
Car: 2007 Versa sl/ cvt
most likely warped disc.
AG
He didn't say that he didn't punch the pedal hard. =)
CodeRed
Hmmmm, Warped disc's are more from fast heating and cooling of the rotors unless you slam on the brakes for a whole car trip then go and wash your car they shouldn't warp. I'd bring it to the dealer and make sure YOU MAKE THE REP DRIVE WITH YOU!
Rockhound
Car: 2007 Nissan Versa 1.8 SL HB CVT
2008 Mazda3 GT
pfc369 wrote:most likely warped disc.
She said that this vibration is present while the car is stopped and in Drive. You feel a warped disc in the process of braking - not while the car is stopped.
Is this just a case of vibration from the engine transmitting through the pedal? Note that engine RPMs change between Park and Drive - which can create different vibrations at different RPMs. Perhaps that's why you only feel it while stopped in Drive.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
This is definitely a vibration from your engine or transmission making its way to your brake pedal.
You mentioned you just got your oil changed... did they use a different kind? Also, did you have your transmission fluid changed?
It's probably something superficial, I doubt that you would have a broken motor or transmission mount at this mileage.
Just for kicks, though, turn off your stereo and drive around for a while. If you hear a single POP! whenever you make a moderate turn one direction or the other, it COULD be a cracked torque rod (which is similar to an engine mount).
NY.AD.MAN
Car: 2011 Nissan Altima Coupe 2.5S (Navy Blue Metallic)
Gone... 2007 Nissan Versa S Hatch. 6 Spd. Blue Onyx - Multiple Upgrades
The same thing happened to me...
It's just that WITH OR WITHOUT ABS, our brakes are a pretty good size, but it is a NEW brake rotor that, even after several thousand miles, is being released into much colder weather than usual.
The humidity here made my brakes wear strangely, so I had the rotors re-surfaced and the problem stopped. If you notice it ONLY on the highway mid-higher speeds, it's because there is a small discrepancy in the form of the actual rotor, kind of like a record that is bent slightly will cause distortion.
SO,
Get the dealership to resurface the brakes and only after this, start worrying about the extreme problems...
Hope that helps!
Versagirlie
thanks everyone, I just made my appt for service, the guy sounded rather odd when I decribed the problem. Ill let you know the status after she gets checked up
Ever Victorious
'73 AMC Hornet
Versagirlie wrote:and now when the car is at a complete stop there is a vibration in the brake pedal, but only when the car is in drive.
For those that missed it the first time...
Occurs only once the car is AT a compete stop, so it's not brake related.
Versagirlie
sooo she went into the dealer today, and it's a cracked motor mount. Its covered under warrenty though so thats good. The service guy also told me to be carefull of where I get my oil changed at, I guess they put stress on it or something and caused it to crack...I dunno it'll be fixed in a few days
Ever Victorious
'73 AMC Hornet
Ever Victorious wrote:It's probably something superficial, I doubt that you would have a broken motor or transmission mount at this mileage.
Versagirlie wrote:sooo she went into the dealer today, and it's a cracked motor mount. Its covered under warrenty though so thats good. The service guy also told me to be carefull of where I get my oil changed at, I guess they put stress on it or something and caused it to crack...I dunno it'll be fixed in a few days
I stand thoroughly corrected.
lizzyland
Car: Nissan Versa
SOO happy to see your post. SAME EXACT thing happened. Went in for Oil change and within minutes out the dealership door, car was vibrating at stop! Thank you so much. Will have dealership check engine mounts. Will let you know what happens!!!
Moghedian
Car: 2009 6-Speed S
Can someone go a bit more in depth as to why oil changes are causing broken motor mounts please?
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
Indeed, I was thinking the same think. The two are not remotely related.
You remove the oil filter and drain bolt from underneath. Replace with new filter and new washer for drain bolt. Unscrew oil filler cap and fill with 4 quarts of oil. Check level. Change done.
Mikiee
Car: 2010 Grey "S"
Does the lift that they are using, somehow put pressure on one of the motor-mounts?
