Yeah mine were insanely hard to get off too. I think there may have been some sort of threadlocker (maybe just a sealant?) on the plugs. I remember having my feet on the longest wrench I could fit under there and pushing against the running boards to get it broken loose. I highly recommend getting a proper square head socket instead of using a 3/8" ratchet extension. The extension is slightly smaller than the plug so you run a higher risk of stripping it out, especially with how much force is required in this case. The square head socket will fill the plug more precisely. They can also be used for the front and rear diffs.McFalconPunch wrote:I tried to replace my transfer case fluid but the fill bolt didn't want to budge. Did check the front driveshaft and the u-joints are good and there is no play. This will probably have to wait until I make another trip to Harbor Freight to get a breaker bar.
