xero1 »
https://forums.nicoclub.com/xero1-u19721.html
Sat Mar 11, 2006 10:31 am
i got a vibration from the rear at 55 mph and up when i accelerate. i have a 95 240 without abs with manual transmission that i just put in. the drive shaft is a one piece drive shaft shop drive shaft(was rebalanced), 350z front and rear rims and stock 350z tires(tires are balance and round), Eibach Sportline springs, kyb rear struts, stock front struts, 300zx front and rear brake upgrade, 5 lug conversion. i took the rear axles apart to look for wear, and the was no major wear in the half shafts. i swapped the half shafts and change the grease. I still have the same vibration. The car have 134k miles, and it had bent rims when i got it. Anyone had this problem?
