Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Jan 07, 2004 2:05 pm
I think you are wasting your time with "snow tires" and below 60F temperatures........as far as trying to get vibration free by balancing the tires.
As to vibration analyser few people know how to use it correctly.I would think a few hours labor [to start].........one would really need to be an experienced engineer or factory specialist to interpret the numbers and intensity.
Errors creep in when the device need the EXACT speed or rpm.As different brand tires in the same size will have different rolling diameters.
Measuring the steering wheel vibration is tricky, Few [only the factory] have the $10,000 special seat sensors that measures your back and bottom vibration with you sitting in the seat.
Years of experience has taught me to just start with NEW Michelin premium [top of the line] tire models [even snow tires] on new or completely tested wheels........the radial force minimize the assembly...........while the wheels are off check EACH rotor for specs.....as rotors can be a problem.
Make sure the motor mounts are new and check each rotating accessory [AC compressor, fan, alternator, ps pump and all the belt tensioners for noise [free rotating feel].Then a new transmission rear mount and a new drive shaft [or measure the frequency of the drive shaft].
Engine oil level is critical as overfilling will allow the crankshaft weights to whip the oil.
