timmack »
https://forums.nicoclub.com/timmack-u74522.html
Fri Sep 07, 2007 4:39 pm
its hard to pinpoint a problem like that without actually trying several different things..a vibration could be a number of things, like the ones listed above or something else. you gotta use the methods listed above to start eliminating things and at least narrowing it down. start with the tires/rims. make sure theyre balanced, properly inflated, and try the tire swapping thing i mentioned above. also make sure the rims are straight. if that doesnt fix it after youre 100% sure its not a tire/wheel issue, move on. driveshaft, front and rear(if you figured out what that was)? u-joints? motor/transmission mounts? you just need to make a list out of all these posts and slowly start eliminating them, one by one. if youre not very car savy, just take it in to a respectable mechanic and let 'em fiddle with it until they find it. like i said, a vibration could be a wide variety of things, no matter what speed it starts and stops.
