elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Fri Dec 17, 2004 12:41 pm
Ok well i did some testing.....
When you hit 75 it is almost like flipping on the switch to the massage feature... Its really bad from 75-80, and then from 80 and on its still there, but not nearly as bad... If you let up from the accel and then hit it again, it gets marginally better/worse, respectively...
From 80 on it stays about the same... Theres a howling that my old Q didnt have, might be noise from the tires and such.... I took it up to 100+ and it wasnt that bad.....
I do know my rotors are warped... So I think ill start with that, as maintenance, and have my rear brake pads replaced..... Then if that doesnt fix it, ill have the tires balanced... IF those things dont fix it, then I know its something driveshaft related... Im hesitant to use anything driveshaft related from my old Q since I know how I removed the engine... Maybe something from the U joint back, as I could see some flexing at the very front part (where the bolts are) as I was lowering the engine.. Probably not supposed to do that, as it states to remove the driveshaft...
However, I may just live it out until spring when I can do skyline brakes You can get kits on eGay for about $300, and Id love to have 4 piston calipers and the ability to use the thicker rotors, which means I wont have to true the rotors all the time...
Edit: I called scottsdale, and the center bearing thing is like $110...
EDIT2: ALso, ill add this little tidbit... I can hear a droning start at about 40, and then it doesnt start vibrating until about 75 like said...
