zinger_usa wrote: when i break it seems to amplify, but i get no pulse to the break pedal. often times i feel it in my steering wheel but the intensity varies. (question: should there be any play in the lower steering column shaft where it comes thru the firewall? i can move it about 1/2) i did hit a huge pothole a year or so ago that was bad enough to bend my stock aluminum rim, but have since had a 4 wheel alignment done.
i recently replaced the tension rod bushings with solid polyeurethane's from whiteline.
To begin with, there should be NO play in the steering column with the ignition switch in the unlock position; either the universal joint is worn or the rack is not adjusted correctly.
Check the wheel bearings for wear which could possibly cause a vibration at all speeds. The easiest way to check for worn wheel bearings is to remove the brake pads. Now spin the rotor by hand and listen for any noticeable rolling or grinding sound coming from the hub which indicates that the bearings are worn.
By replacing the tension rod bushings with solid polyeurethane bushings, any problems with the front suspension will be more amplified; the OEM silicone filled bushings are designed to absorb a lot of suspension. vibrations.
You also mentioned that there is abnormal wear on the front tires which indicates possible incorrect alignment; something else to check.
