Big Dawg1 wrote:nissanfreak12:
You say th u joints are not meant to be replaced? Then how do they get repaired? The rear Ujoint had a lot of slop in it (177,000 miles) so I thought it should be repaired along with the Transmission. They sent the rear shaft out to a drive shaft repair shop that takes the old ujoints out and presses in new ones. Are you saying that can't be or shouldn't be done that way?
As far as the center bearing...I don't know about the spacer. I would assume they put it back. Is there a visual way to tell without having to remove everything?
The only way to repair is to replace, all they basically are needle bearings. The 300zx DS was never meant to have u-joints replaced nor repaired, they are a very specific u-joint, which were non-serviceable. They designed it that way so you would just buy a new DS or to bring to a nissan dealer for them to tell you you need a new one. Some have gotten them repaired, but generally they fail soon after.
The spacer, yes you can visually see if they have one, but they are not always supposed to be there. They look just like thick washers.
U-joints in general can be replaced, like in my Jeep, easy to replace. Just the Z they are not serviceable. Hope this helps.
