Vibration @ 2250 rpm
q45mqn
I have search for the post. Can some one point me in the right direction?I have owned a 1995 q45t almost from new and it has always had this issue. It seem to be getting worse now that I have gone past 100,000 miles. It is a deep vibration felt in the steering wheel and seat.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Check transmission mounts, driveshaft, and exhaust.....
Does the vibration happen at a certain RPM, regardless of how fast you are going.. Meaning, can reproduce when you rev the engine to 2250 RPM in park?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Depending on your tire size, it will be at 45-50 mph in 3 and 68-73 mph in D if it is the transmission (rear motor) mount. Count on replacing it anyway (along with the exhaust hanger bracket) if the service history doesn't include it.
The post is in Infiniti Mechanic Forum, where this one should be.
Modified by maxnix at 12:20 PM 12/7/2005
goody90q45
Car: 1992 Infiniti Q45 (sold)
I agree. Start with the easy stuff. Replacing the transmission mount and exhaust hangers is an easy DIY that will cost about $130. If it hasn't been done it's time. You willl eliminate vibration at all RPMs that you don't even know you have. I did mine a few weeks ago. Check out the thread that Maxnix referenced, it's all there including pics.
q45mqn
Wow! this forum is great. After driving my Q for 10 years and suffering in silent what a fantastic discovery to learn that there are others out there who can solve my problems.The vibration does not appear at 2250 in idle just in D
q45mqn
maxnix wrote:Depending on your tirer size, it will be at 45-50 mph in 68-73 mph in D if it is the transmission (rear motor) mount. Count on replacing it anyway (along with the exahust hanger bracket) if the service history doesn't include it.
I am confused about posting procedures. Is this not the Infinite Mechanic Forum? The search feature is currently disable so I have not been able to locate post on how to do rear monts and exahust hangers.
elwesso
2007 BMW M Coupe
I moved the thread into the online mechanic, it is hard to find since our side menu is being changed right now..... should be where it should by the end o fthe week.
the search function is down because we are moving the search thingy to a dedicated server...
96Qowner
Car: 1996 Q45
Here ya go:
zerothread?id=141980
Found it by paging back through the posts.
q45mqn
Thanks man. Sounds like I need to torch the pre mufflers. The car has had these symptoms since 1996 when I bought with 5,000 miles on it.
Modified by q45mqn at 8:53 PM 12/7/2005
q45mqn
Cannot find a listing for Exhaust Hanger Bracket at "everything infinite".Does anyone have a part number or a more accurate description?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Call them. I may be able to find mine, so I will post it if I do.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
20610-60u00 $12.59/ea you need two.
3rd Q
GQ Jay wrote:20610-60u00 $12.59/ea you need two.
Yep, they have them. Just bought some last week.Paul
rob1
Car: 1994 Q45
GQ Jay,
Noticed you live near me. Any recommendation for a reasonably priced mechanic to replace struts?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Rob- sent you mail.
