NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Sep 09, 2005 5:03 pm
When you remove the bolts from the bell housing and you are basically ready to drop it, you need to slide it back about an inch to clear the dowl pins and rotate it 90 degrees. Also if your doing this on the ground use a floor jack and a peice of 2x4 to push up at the crank pulley. This will give you the best clearence to get it out. The hardest part is to get the bell housing, primarily the starter boss, to clear the floor pan when removing it.
