Vibrating brakes on new rotors and pads
Kirkland91
Car: Infiniti m35s
Had my brakes vibrating at 60+mph speeds.
Got new breakomotiv front rotor and pads and same issue appeared again after install. Does anyone have any suggestions. Happens only when brake at speeds of 60+ .
szh
Car: 2018 Tesla Model 3.
You might try getting your tires properly balanced. This will also help a lot!
Z
Ilya
And if it's not tires, how were your breaks bedded in? If they were bedded in incorrectly, the pad could have left an imprint on the rotor, thus you get slight vibration.
TOMatBMR
Car: 2006 M45 Sport
Does the vibration occur on or off the brakes? Were the hub surfaces cleaned before the rotor was mounted? Does the vibration occur in the steering wheel or do you feel it more in the seat?
