95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Tue Dec 19, 2006 8:53 am
yes, but what if the rim was cracked, or the rotor is slightly bent, you could jack up the passenger side, and rotate the tire manually, that might give you a clue. the next thing i would do is to get the front rotors out and machine them, mark the passenger side one, if it is bent, the shop will mension it ....... hope this helps
