maxnix wrote:Man, that guy was stupider than an unpolished turd for not only revving stone cold , but not turning it for a few seconds first with the fuel pump fuse pulled to prime the HLA. Wait, on you Tube you comment you went to solid lifters? How did you get rid of the HLA and why?Also, kind of curious you installed it in the car and then are ripping it out to bench tune it.Anyway, nice job, but start it yourself next time. You need to consolidate your build write up when you are finished because you have done the best job so far. But I am curious how you arrived at your camshaft lift and timing with no bench work before hand?
It wasn't revved stone cold! This was a statup of the engine after it had already been warmed up and run for about 20 mins to check for leaks, oil pressure etc. and get enough of a map in there to make it even idle and rev cleanley - had more to worry about than video on the first start! Oil temp was 70° and coolant was at it's setpoint of 75 whe this vid was taken.Also, if you notice it takes a while to catch when cranked, thats because there is an ignition kill switch which is used to kill power to the injectors and coils until you see the oil pressure come up on the gauge. Obviously there are no HLAs to prime in this engine.
Went soilds by just having lash adjusters machined to replace the HLA's, they're adjusted by shimming. Got rid of them as the cam profile would be to aggressive to use with them and the rev limit is going to be over 8k.
I'm not going to rip it out to bench tune it, will do it on a rolling road. Ideally I would have liked to engine dyno it first but it was just way too much £££ to get a bellhousing made up etc etc.All of the stuff on this, cams, manifolds etc. is done just from experience of what has worked on other engines and working with experienced engine builders. If it's all wrong and it only makes 200bhp then hell, I've only got myself to blame.Cam specs are 280°@50' 30/70 70/30 10.2mm lift - on grind when VTC active, retarded when off. The profile is a well proven piper grind which usually nets ~110bhp/l on 4 cyl engines.CR 12:1. Exhaust manifolds are 41mm ID, 1m primary length which is tuned for around 5.5k peak torque.Intake length will just try it on the dyno and see what works but hemholtz suggests anywhere between 10 and 30 inches will work depending on where you want them tuned for. The air box I'm making will allow for anywhere between 1/2" and 30" runners before the trumpets so plenty of room to mess about.I will consolidate it all at some point no doubt did a shortish write up on one of the UK 300 sites but it's not very technical.
