Stinky wrote:I'd have to vote against the vg30e (Z31)/S13 trans. I shredded the teeth off of third gear and the car was barely over 300lbft. If you're plan on it lasting a while find a Z32 transmission or some variant of it.
Huh, I thought the Z31 and Z32 trannies were the same. Live and learn.
tkmhkm wrote:Ok sorry about getting the 300z and 300zx mixed up its been a long day...Finally got my rebuilt ka running in my roommates car and the radiator cracked and almost overheated the motor......Time for an upgrade! But I don't mean to sound stupid here but an S30? what is the difference between an S30 and an old school Z. I read that the 88-89 model turbo old school Z's five speeds have the same internals as the Z32 transmission just different gear ratios.
There is no 300Z
S30 is the chassis code for the 1970-1978 240, 260, and 280Z cars. S130 is the chassis code for the 280ZX. Z31 and Z32 are the chassis for the 300ZX (The Z31 is a more angular looking one, similar in style to the S130). Z33 is the 350Z, and then Z34 is the 370Z.
As for the 88-89 models...I'm not sure. Those were Z31 VG30et cars, and according to stinky (who I have no reason to doubt right now), they didn't have the same bulletproof transmission that the Z32 series did.
I guess it all comes down to power goals and transmission availability. If you really can't find a Z32 VG transmission even in a junk yard, (and if machine shop time is cheap for you for an adapter plate), then I'd vote (in order of preference):RB255 speed from a L series Z car (S30 and S130s with the straight six)4 speed from a L series Z car
Though realistically, you'll probably save yourself a ton of headaches if you just shell out for a good VG transmission.
edit:Actually, if machine time is cheap for you, why not find a T56 or some other newish GM transmission? Those things will last all day and all night on almost any power you could expect to put through them and still have the rear wheels hooking up.
