Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Apr 13, 2009 6:09 pm
In Japan, the Q45 was sometimes sold as the "Nissan Infiniti Q45" and sometimes as the "Nissan President"
Many JDM take-outs have the Nissan badge. Since JDM take-outs are considered preferable to ones from US junk yards, the badge is also swapped out by sellers trying to fool you into thinking that it's a JDM takeout, rather than a 200K US junk yard pull. Another telltale sign is that the pre-cats are on the US engine exhaust manifolds, but not on JDM engines. In this case, the exhaust manifolds have been removed - so that's not a clue here.
This engine appears to be out of a 1994+ Nissan President. I'm basing this on the fact that the rocker covers (a/k/a valve covers) are attached by nuts instead of by bolts. This engine would be a good candidate for a 94-95 Q45, but not your 1992.
So the engine has the same block but different heads, and sadly different connectors to the sensors than your 1992. I would continue to look for a 90-93 engine. Although I have heard of some rigging up the wiring to make the switch, it is much easier to rehab and install the correct engine.
Heath
