elwesso wrote:IM interested! If you think your getting at least 70+HP out of the cams.....?
if you can get me a set of cams for $300 US, sign me up!!
well i was told 50 rwkw gain with turbo application and 90 rwkw gain with naturally aspirated setups!
However i believe the NA setup was a pretty intense setup (aftermarket ecu, headers, individual throttle bodies, etc ... so obviously the cams were holding it back! So as always when you remove the biggest restriction in a setup you get the biggest gain!
So yes i would expect 70+ rwhp gain to be a realistic figure. perhaps even a very conservative estimate of the power gain! I will know of the gains with turbo application as soon as i get the cams back and the 850cc injectors in!
Like i said ... the grinds are $400 AUD ... $100 / cam ... billets are available also for more money
