Can somebody please verify that this is the correct operation of the VTC on VH45DE's?
http://www.nissanv8.com/viewtopic.php?t=57
If these diagrams are correct it looks ***-backwards. Look in the power graph how the torque peak is higher in RPM when the VTC is on (but is on less than 4600 RPM) and the torque peak is lower when VTC is off (but its off when less than 4600 RPM).
This can't be right because this looks soooo backwards. Was this done for low RPM emissions or something? If the diagrams and output graphs are correct... then we should get significant gains by doing the following:
1. turn VTC off below 4600 RPM, which moves the torque peak lower (which is where you are in the rev range),
2. turn VTC on at and above 4600, which moves the torque peak higher again (which is where you are in rev range)
This will result in a sort of double torque peak (or a wide torque band if you smooth it out). I'd be interested to see dynos from someone with torque/hp curves for:
VTC always off - easiest way is unlug it, assuming that it doesn't piss the ECU offVTC always on - connect 12V or 5V (not sure what is sent but I'm pretty sure its just DC and not some kind of PWM since its always on after a certain RPM point)
That way we should see what kind of operation gives the best performance. Also I would be really interested in seeing people with custom cams try this. I know it requires two dyno runs which costs money, bu I think you may be pleased at how you may be able to regain some of the lost low end that typically comes with hot cams.
Discuss
