ive looked through the site already, a lot of nice stuff, and we might buy a wiring harness from them. but the point of this build is to do it as cheaply as possible, which is why i need to know if the factory auto transmission can be utilized. dont get me wrong, i would love to have that kit, but money is limited, so we'll be sourcing most things from salvaged cars.lowe300zx wrote:Check out http://www.mazworx.com They have a kit for dropping the VH45DE into an S13. It includes the motor mounts, a driveshaft, and an adapter plate to use either the stock 240 transmission or a Z32 transmission and a couple other necessary parts
yeah, thats the thing, its going into a 5spd chassis.Carl H wrote:if you do the wiring right there is no reason it should not work.just start with an auto chassis and go from there, do not use a 5spd car.
well, were trying to spend the least amount of money we can, and to do that, wouldnt we need an adapter plate and a flywheel spacer? fabbing that ourselves is a no go, so we would have to pay someone to do it.PanzerAce wrote:
yeah right now, we have a whole lot more time compared to money, plus i got a local guy thats very good with wiring, so his help should speed things up a little.PanzerAce wrote:It comes down to time vs. money though. If you have a 5spd, the wiring is easier and you get on the road faster, but you have to spend a few hundred more bucks. Personally, I'd go for the 5spd, but it's up to you.
