gs14racer what size pulley did you use when you where running 6psi? and was it off the alternator belt?gs14racer wrote:because of the rotation of the vh45de and the way the supercharger has to be mounted. You can only use a v2 ccw rotation off of a 4.6 mustang or similar. The v1 off of the 5.0 will not work.
You can probably find out more information regarding gs14racer's setup by searching his posts over at v8nissans.compoorboys14 wrote:gs14racer what size pulley did you use when you where running 6psi? and was it off the alternator belt?gs14racer wrote:because of the rotation of the vh45de and the way the supercharger has to be mounted. You can only use a v2 ccw rotation off of a 4.6 mustang or similar. The v1 off of the 5.0 will not work.
