First, I was there very recently. Its all good. First, you need more battey power. the clanking sound, is the timing chain slack. It went away after starting it the first time. Before that, it was scarey sounding.The whine, well, I had a few sounds like that at just cranking for the first time in 4 years kind of sounds, they too went. the walbro, I can say, I can barely hear at the tank. Not loud really. hold the fuel line, have a buddy turn it on and off, if there is a fuel pulse, you Will feel it.Use a set of Noid lights to see if injectors are firing. Is Red light on side of computer?CrazyTrance wrote:So i finally got around to trying to start my vh'd 240sx (s13). FIrst problem was that the fuel pump didn't prime. I know this because its a walbro 255 and it should be LOUD. So thats mainly why it didn't fire.. but anyways.
But something that concerns me is that when i turn it over it seems to turn over very slow. And it has a whine to it. Also something that really concerns me is that there is a clunking noise coming from the front of the engine when it gets turned over. I know for a fact that the timing chain guides were replaced because i took the front covers off to check. I should note that thecar was hooked up via jumper cables to my integra. Wold this be part of the reason for the slow cranking over? Or is poor grounding to blame.
Also, when i took the valve covers off the aluminum inside looked BRAND new. Here are pictures of my exact heads. There is very little if any abnormal wear on the cam lobes. So seeing these results i would think this engine should be good with no problems... right?
Passenger side.
Drivers side.
Thank you, yeah we didn't rev the engine up at all.. so that might be what you are talking about. And i have not gotten a battery for the s13 yet. It was just hooked up straight to the ground and power cables with jumper cables.npez wrote:Can't comment on the clunking you're hearing as that could be a 1000 different things; but a couple of things you may want to look at. 1) Rev the integra to about 3-4K when you're cranking the VH as the alternator on the integra is putting out hardly any amps at idle and the honda/integra batteries are typically pretty small. 2) Are you positive that you have a known good battery in your S13? A bad battery (dead cell, etc.) will act like a load when you try to jump it and may cause the starter to turn slow. You may want to disconnect the battery on the S13 and jumper directly to your +/- pole wiring without the battery connected. 3) speaking of wiring you may want to check that you have good wiring to the starter as well as a good ground wire between the (-) pole wire and the chassis as well as the grounds from the engine to the chassis.
If this doesn't correct the slow crank you're experiencing, it could be a weak starter, or an inordinate amount of load on the starter due to a mechanical issue with the motor.
Just some thoughts to get you started....
Nick.
Holy crap craig. You have jus made my night. I've been stressing out so much cuz i've been thinking something is seriously wrong with the engine. Hopefully its just like your talking about. That clunking noise has seriously gotten me worried but what you said makes sense and i did kind of think of that but wasn't quite sure.craigztoyz wrote:
USE STARTER FLUID AT THE MAF> Works great to find if you have spark, and if oyou have it part throttle, and a good spary, you can keep it running to build up some oil pressure. Kept mine running for over a minute.
Past that, give me a email, we can chat when you need, and I can walk you through it, and try to help.Oh yeah, are you SURE it has good grounds for the ecu? Use a test light to be sure you have power at all you r power wires, and that the relays are getting trigger wires. Do you have the cranking wire hooked up? I went through my wiring 2 times trying to figure out why mine wouldnt start, and what I jsut said was a large part of the diagnosis process. Good luck, Craig But first get lots of battery power, this thing should freakn fly when the starter is hitting it.
Thank you SO much for your informative information... how does that help me. I have mine wired also. But not correctly apparently. The red light on the ecu is on, what does this mean? Also i have no spark as it does not fire with starting fluid..Carl H wrote:lol, wiring this engine was easy...i had that done 4 weeks ago.
The LED on the ECM is a good thing - it means it's on. I suspect you've got a weak ground somewhere. As I suggested to Craig when he was having a challenge with his, take all your ECU grounds tie them together and ground them to a single grounding point. Also check your battery ground cable and make sure you have a good connection there, as well as the grounds from the the motor to the chasis. You'll see grounds going from each power transistor to the back of the engine make sure they're still connected.CrazyTrance wrote:
If you could post what wires you wired in or some sort of diagram that would be really helpful. My EGI pump relay is fluttering uncontrolably, so something is wrong.
Modified by CrazyTrance at 12:46 PM 8/2/2008
Thanks for that!npez wrote:The LED on the ECM is a good thing - it means it's on. I suspect you've got a weak ground somewhere. As I suggested to Craig when he was having a challenge with his, take all your ECU grounds tie them together and ground them to a single grounding point. Also check your battery ground cable and make sure you have a good connection there, as well as the grounds from the the motor to the chasis. You'll see grounds going from each power transistor to the back of the engine make sure they're still connected.
If you look on NICO/VH45 forum I have written up a pretty comprehensive 300zx->VH45 wiring integration document that explains all the wires with corresponding 300ZX wires. Not a lot of help when cross connecting to a 240, but it will give you a lot of information that wil help you understand where the fault may or may not be.
I hope this helps out a bit....
Thanks,Nick.
I assumed you had all the relays connected - oops. Yes if there is no IGN relay you won't get spark. The ECM only knows to provide ground to the relay coil to close the contact and complete the cicruit to the power transistors. You'll notice in the diagram that you have (+) going to the relay through a fuse/fusible link, then power going from the other pole to the power transistors. On the other side of the transistors, they are individually grounded hence completing the circuit.CrazyTrance wrote:
Thanks for that!
ok. so i've been looking through the q45 fsm to figure out why i'm not getting spark. I have power to the coil packs and the power transistors are connected directly to the ecu. So there should be spark right? WRONG
Yes, everything is hooked up like it should be. But i am missing one important thing. The ignition coil RELAY.
Why? Think of your fuel pump. When you turn the key to the on position it sends a signal to a relay, which in turn sends a signal to your fuel pump control unit which finally tells the fuel pump what the **** is up.
So in this case, the power transistor doesn't know what to do because i have NO ignition coil relay telling the ecu that yes, ok i have the key turned on. So it doesn't send a signal to the power transistor which in turn doesn't send a signal to the coil packs to turn the **** on so i can roast the **** outta my tires.. So no signal, no gravy.
THAT is what i think is wrong and why i have no spark. I'm not 100% sure yet, but i'm pretty sure this is what the problem is. I'll let you guys know for sure tomorrow. Or if i'm still stuck in a ditch, moving nowhere fast.
So let me know what you guys think! Think i'm right?? Or am i just making **** up. Post!
ANyways, here is the diagram for the ingition signal system and why i think what i think is right, or should be right.
P.S. no i didn't write on the actual book damnit. i have a tablet pc. used an editing program to write it with a paintbrush. so back off
That is EXACTLY what i am thinking. I didn't think i needed to add a relay for some reason. but if the car never had one well... then.. yeah.npez wrote:I assumed you had all the relays connected - oops. Yes if there is no IGN relay you won't get spark. The ECM only knows to provide ground to the relay coil to close the contact and complete the cicruit to the power transistors. You'll notice in the diagram that you have (+) going to the relay through a fuse/fusible link, then power going from the other pole to the power transistors. On the other side of the transistors, they are individually grounded hence completing the circuit.
You also have power going to the relay coil from a fuse/fusilble link and the other side of the coil goes to the ECM. As soon as the ECM provides the ground you end up with power to the power transistors.
Hook up the IGN relay and you sould be ok.
Thanks,Nick.
Could you elaborate on that?Carl H wrote:lol, lack of an ignition coil relay is hardly the problem...problem is how you have the power routed or rather dont.brown/yellow wire thick gauge wire needs to be on switched 12v power.
I checked them, i even tried another cas but that one could have been bad because i kinda handled it roughly over the past couple of years although it came out of a RUNNING q45.Carl H wrote:check your cas connections, i have seen a car inject fuel but not spark due to bad cas connections.ive even seen a car spark but not spray fuel because the cas was bad.pull codes and see what the ecu thinks is wrong.
Also, if you could post the wires you had to cross over or a diagram if you made one that would be great if its not too much trouble, I'm having the worst time figuring this out.Carl H wrote:check your cas connections, i have seen a car inject fuel but not spark due to bad cas connections.ive even seen a car spark but not spray fuel because the cas was bad.pull codes and see what the ecu thinks is wrong.
Yes, i checked for power at the injectors, and i have power. So the ecu is just not sending the ground pulse for some reason. Could be my CAS.craigztoyz wrote:I am pretty sure he already did test for inj power. The noid lights, are a lil box of 5 lil lights that have a led bulb, and each fits a different injector type. Are the relays all triggering?
If you still have problems, check power and ground at each point from ecu.
Do me a favor. Post up, where you do and don't have power please. and a brief bit on what is working and not. craig
