VH45de s14
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
wicked!
anyotherone
Car: '93 S13 coupe VH45
Sounds good! I've always preferred the tone of v8's with an X-pipe as opposed to true dual or H-pipe.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Hotness.
Carl H
your welds look much improved over your first version of the car...but you're also welding with gas now; world of difference no?what material are the mufflers and pipe, looks like ss but i cant tell.
gs14racer
thanks, yea ive had gas for a while now, cant imagine what i ever did with out it. The whole exhaust from the headers back is stainless.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
You've taken the car to another level with this build. Props for doing a great job.
gs14racer
Thanks, hows the turbo Q doing, any dyno numbers yet. Thats what i really wanted to do, just not enough room.
sijoko
The turbo Q is running 7.5 psi of boost without any problems. The trans is getting a bit noisy so I need to plan on changing it in the future.
I've still got some other things that need to be done like the exhaust after the turbo. Right now, it has some stainless steel flex tubing for the center part of the exhaust. It works but clearance is an issue so I need to look at some oval tubing.
The car is out of the picture at the moment. Last time I drove it was about a month ago. I've got it parked at my Mom's place in Atlanta.
gs14racer
nothing much to report, im waiting on parts again to finish the engine bay, and for the brakes. Im trying to get the car driving so i can take it to get painted next month and be done for now.
So as a result of killing time , im building a new harness for the engine, getting rid of all the stuff im not using and tucking it away for less visibility.
Example coil pack harness before
After
Still a work in progress hope to have the car drving soon.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Beautiful work. Really nice job on the exhaust and the motor looks amazing. I've been thinking about redoing some of my exhaust too. I know I have a few small leaks pre turbo. Might spool a little quicker if I fix them. Every little bit helps.
tmorgan4
Car: 2000 Nissan Pathfinder
That's a great idea for the coil pack harnesses! Did you just cut the connectors with a little wire left and add in some fresh wires? It's difficult to find good coil pack harnesses. Every set I've ever seen was cracking and about to fall apart.
WizardBlack
Car: 1977 Datsun 280Z w/ RB25DET
gs14racer wrote:i really wanted to do, just not enough room.
Aww.... c'mon. If it can be done in an S30 it can be done in an S13/S14... :-)Oil sump is key.
m280sxgt
Car: 1995 Nissan 240sx with AEM Short Ram Intake, KYB GR-2 Struts, Eibach Lowering Springs, HKS Hi-Power Exhaust
Reading up on this forum and watching you go through and make this car a reality makes me want to do it to my daily driver. Granted I think that would mean no AC but oh well.
gs14racer
Well been busy all week, got the engine harness done, it was a pain but looks much better. Plus i got to cut out a lot of unused stuff.
before
Moved the ignitors to the inside of the car, and finish both coil pack harnesses.
and here is the main engine harness
The tags are where i have to add another plug
sijoko
Very nice work. It will let people see the beauty of the VH instead of a bunch of wires. LOL.
gs14racer
well got a bit accomplised today.
Got a fan for my radiator, its a ford taurus dual speed fan, alot of mustang guys use them , and from just turning it on attached to my radiator it has twice as much air flow than the dual flexalites i had before. Plus it has a built in shroud and with a little trim it fit my rad perfectly, except for an inch or so that hung below the rad, which ill fix with a peice of aluminum.
Also made the braided hose for the catch can (which im fabbing up later this week) and installed the wiring, plus i was able to get the brake booster back on as well.
I love the fact that you can hardly see any wiring on this engine, and its all there
Lastly made the mounts for the radiator to sit on and got it in the car, im almost there lol.
sijoko
I'm running the Taurus fan on my Turbo Q. It moves a lot of air so you will have no problems. Just make sure you use a heavy duty relay and wiring since that thing pulls some serious amperage on the high speed circuit.
The engine bay looks very nice. Are you going to put the ornamental covers back on the valve covers?
Clifton
Car: 73' 240Z/7MGTE 71 240Z/L28ET
The wire loom looks great. Better than factory.
FWIW, my Taurus fan pulls about 60A on startup and runs at 30A on high, 15A on low.
gs14racer
Well Ive been really busy with work lately so these arent the most current pics but for what its worth the car is running, just have to finish up the brake lines.
Undercoated the both wheel wells
Made my own high pressure steel braided ps hose, and did the nylon braid for the return to the power steering cooler. They run real close to the headers so i put the heat sleeving over them.
Ballerific alluminum drive shaft
Here you can see where i put the fuel filter, the engine bay was too cluttered so i put it on the bottom of the car, the zip ties where just temporary, its all clamped in place now
Here you can see the power steering cooler, hopefully it wont boil over any more
Also got the expansion tank mounted , its at the highest point so i should have no air bubble problem since the radiator is lower than the water outlet
Also got rid of the origin sides and rears and bought another set of jdm zenki sides and valences, much better imo.
Thats it for now maybe ill get some dyno vids in a week or two then its off to paint.
PresidentV8Fan
Car: 1989 Nissan 240wx
I've been a back seat reader here...but great work
gs14racer
praise the lord, the engine is done. It starts and runs and idles and all, i have a few loose ends such as the catch can and such but nothing major. Now i can paint this f@cker and take it to the track.
Will be getting the radiator support powdercoated soon as well
Heres some pics
Should be able to take it for a spin around the block at least tommorow, just have to clean up this mess
gs14racer
Well busy weekend, got the front end mocked up and hood pins installed and pretty much got eberything mechanical wise put together.
Which culminated in this
YouTube - VH45de S14 first drive again 2008
The whine you hear is the p/s pump as i had no fluid in the system,
We ended up removing everything that wasnt bolted down and took it for a spin, unfortunatly the vid is pretty uneventful. When i was further from my neighborhood i opened her up, it will destroy 315 azenis from a roll in second gear and if you go first thru third its amazing, i couldnt take it out too long as it was getting dark, but all in all great ride
Heres some more pics
Serious buisness
sijoko
Just watched the vid....car sounds awesome. I'm looking forward to some in-car vids.
So did the later headlights and fenders just bolt on? I've always liked the front end of the final 240sx.
SuperHatch
Car: 96 TLC
Lookin great as usual! Sounds great too! Can't wait to see and hear the finished product...
boonseyQ45a
Car: 1994 Infiniti Q45a
Wow!!! I am in awe when going through this whole thread.... you are showing some good improvements on the welds, nice color choice, good to have you kept the VH motor in the Nissan family, wicked wheels w/crazy offsets, man this car doesn't end... keep all of us posted......
mitchell
Modified by boonseyQ45a at 12:14 AM 10/30/2008
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
hey jerry i'm a total newb to this site and to nissans, i have a 96 S14 i was wondering what diff you are running cause it looks different than the one in my car? thanks
newbissan-tech
also what did you do with the two extra holes in your valvecover and where did you get that oil cap?? scratch that i found the oil cap!
Modified by newbissan-tech at 2:16 PM 11/2/2008
gs14racer
Well made it to the dyno today, did a couple of pulls with a few different tunes.
1st pull base line, headers / exhaust
2nd pull left the vtc till redline no other changes, picked up a few hp up top tq remained the same
3rd pull vtc was stock a few degrees of timing and a little leanerBig diference in tq below 4000. Best pull of the the night.
So the most power was 283hp 293wtq. I think with a little more fine tuning 300whp 300lbft tq is very achievable, we shall see. Ill have the .drf's tommorow and can over lay the 3 on winpep.
Heres some vids
http://www.youtube.com/watch?v=NaYO047C2Mo
http://www.youtube.com/watch?v=8d69o4Unflc
Unnatural1
Wow...nice numbers. That might be the most power out of a NA VH45DE we've seen posted on NICO so far. Regardless, those are strong numbers and make me jealous! My Q could definitely use nearly 300rwhp...or more.
boonseyQ45a
car sounds mean bro...... those are some crazy tq for the 240 man..... if you achieve 300hp/300tq, it'll be easy get your car sideways, its probably doing that right now...... keep us all posted
mitchell
Return to “VH45DE / VK45DE / VK56DE Forum”
