VH45DE PRO Plug-N-Play Harnesses are now in stock! Series 1 & 2 supported.
$599 intro price till Nov 1st - save $50!
Check out the chassis-specific links below to see available options for ECU, injectors and transmissions.
Order online, call or email [email protected] for details, questions or orders.
This Wiring Specialties Pro Series Wiring Harness includes the engine and transmission harnesses for a Nissan 240sx S13/S14, Z32 300ZX or other chassis with a VH45DE engine swap. It was developed in house on an actual VH45DE engine and comes tucked for a clean finish. The harness is designed as a one-piece unit with integrated OEM COIL, Injector and transmission harnesses for clean install.
Engine: Infiniti Q45 VH45
- Any VH45 from 1990-1995 Infiniti Q45
- WILL work on 1996 model with adjustments
- Any S13 240sx manufactured in 1989-1994 (Including the Convertible and ABS cars)
- http://www.wiringspecialties.com/240sx- ... g-harness/
- Any S14 240sx manufactured in 1995-1998 (Including ABS cars)
- Any 300zx Z32 manufactured in 1989-1996 (Including the Convertible)
- http://www.wiringspecialties.com/300zx- ... g-harness/
- Any non EFI vehicle and custom built race cars, Datsun classics, Nissan pickups.
- http://www.wiringspecialties.com/univer ... g-harness/
PRO-SERIES HARNESS FEATURES
- Plug and Play for S13, S14, Z32 & Universal
- Significantly lighter than a factory harness
- NO CORE HARNESS or additional wiring required
- REQUIRES use of NEW style Ignitor Chips
- REQUIRES use of OEM Coils
- Available with New or Early style injector connectors
- Available with New or Early style CAS and TPS connections
- Constructed using OEM connectors and seals
- Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing
- Wrapped in lightweight nylon loom with -94C to +257C operating temperature
- Includes a charge harness and improved grounds
- Fully tested after production for an easy plug-and-play replacement
- Turn Key ENGINE START Guarantee
- Tech support for our customers 7 days a week.
- One-piece design with integrated Coil, Injector and transmission connectors
- Alternator charge cable.
- Nissan Diagnostics connector.
- Power and dash interface connectors.
- Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
