VH45DE -> Powerglide Adapter
Ezekial
Car: 2001 Nissan 200SX S15
Anyone want one?I had mine copied ...
No spacer needed behind the auto trans flex plateNo starter motor problems
Uses factory bell housingUses factory auto trans flex plateUses factory starter motor
Powerglides are a dime a dozen, CHEAP and can withstand RIDICULOUS amounts of hp ...
About 20 cm in diameter so freight would be no drama's what so ever
If anyone wants one ... let me know ...
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
What is it?
velvet hammer
Car: 1990 jdm Q45a 60000miles on the clock
an adapter plate so u can use a powerglide auto transmission on your vh45de , normally used in high hp drag applications.
qship96
Car: 1996 Infiniti Q45
Why on earth would one downgrade a factory 4 speed automatic q45 transmission to a antiquated 2 speed General motors powerglide transmission? TWO SPEED transmission IS A RELIC OF THE PAST!,hell,the 4 speed auyo transmission is close to being a relic of the past itself!!!
Haitian_King
Ok then. That answers that.
I'd maybe go for a plug and play 5 speed auto.
Rex
Car: None
qship96 wrote:Why on earth ...
velvet hammer wrote:... used in high hp drag applications.
It really all boils down to your use of it.
velvet hammer
qship96 wrote:Why on earth would one downgrade a factory 4 speed automatic q45 transmission to a antiquated 2 speed General motors powerglide transmission? TWO SPEED transmission IS A RELIC OF THE PAST!,hell,the 4 speed auyo transmission is close to being a relic of the past itself!!!
True , but i dont know of any vh45de equiped cars running 10sec quarters that still use the infiniti box
Haitian_King
Is that even street legal?
How safe could that be?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
First of all, if you dont understand its use then dont flame it.
People who use this adapter would most likely....
1. Not care about street legality2. Not have the VH in a Q.3. Would be running at least 10 second quarter miles.
I still like the TH400 better than a powerglide I think but when you put down that much you probably would only want to shift once during the 1/4 mile.
Bottom line is, itd be used on a drag car with a ridiculous setup. For that, itd work great, otherwise it wouldnt...
posting this in the Q forum may not have been a great idea since most Q guys dont "get it".
Haitian_King
Thanks for the explanation.
I think I'll hold out for a 5 speed auto.
BTW, if you're not running a VH in the Q with the powerglide, what would the car be running?
elwesso
2007 BMW M Coupe
Haitian_King wrote:Thanks for the explanation.
swap it in something else like an S12 or and R31!!
Q45tech
http://www.mathworks.com/produ....html
"By UNDERSTANDING a problem, fully, a technician can then repair the transmission and SOLVE the inherant problems that lie within".
http://www.geocities.com/firebat99405818/jae02.pdf
http://www.geocities.com/firebat99405818/Look under publications and you will find 20+ technical papers on automatic transmissions. J.O. Hahn Phd is obviously an MIT expert on transmissions
A 0.1 second shifting transmission.http://www.autospies.com/news/...22472/
http://turboneticsownersclub.com/simi/5AT1.pdf
http://faculty.haas.berkeley.e...n.pdf
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Rex wrote:It really all boils down to your use of it.
I believe the Chaparral CanAm cars used pwerglides also.
http://www.photoessayist.com/c....html
