vh45de or vk56de which is better?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
67 411
Car: 1967 datsun 411 sss wagon 1975 datsun 620 king cab 4x4 and a 1971 521
Ok guys i am planning on doing a engine swap in my 71 521 but im not sure which engine i should use. I am stuck between the vh45de and the vk56de i am planning on going with a single big turbo The thing is i want a manual trans also. So what engine do you guys think would be a better engine, Also i would like to get atleast 500 horsepower out of it.
Q45tech
500 flywheel hp at what rpm and psi of boost ---- super or turbocharged?
That extra liter makes it easier to get 100 HP at the same rpm.
hannibal
Car: Red Line to Glenmont
^ Are you now copyrighting your posts?
67 411
what are you talking about?
67 411
I am looking at doing a single turbo and i like a kind of even power curve and i guess 500hp around 5-6000rpm i have herd thet on the vh you shouldnt run more than 8psi. Also i dont think i can get 500 rwhp on stock bottom end, can i?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
basically on a VH45 what sets you back are the stock injecors and the compression ratio... You can run all kinds of boost on the stock internals if you can change the compression ratio, and the valve springs (they are a bit weak)
67 411
so is there a company that makes the springs or do i have to get custom ones, i found cp pistons on ebay but they are kinda spendy and i hadnt heard of them before, are thay a good brand?
I found a dyno run with the vh45de in a 240sx turbocharged sounds good
http://videos.streetfire.net/v...9.htm
67 411
so i am pretty sure im useing the vh45de with a single turbo, is it true that the ka flywheel bolts to this engine?
67 411
so the more i research what i have to do to put this engine in my truck and make the kind of power i want, the more i think it would be alot cheaper to put the vq35de in it and run a twin turbo kit. I really like the look of the vh45de and they sound good, but now im not sure what im going to do.
darinz
Car: Nissan Patrol
I had a VH45 with a T04z in my truck. Dynoed at 375 rwhp at 10psi but I was running avgas. A mate is running one in a his Titan offroad race truck and that has 480hp at all four wheels. That is sc and I think running 13psi.You can do whatever you want but if you want off the shelf cheap then use something else!
sidewaysvk56z32
Car: 1990 300ZX
im looking to do a vk56 swap in my z32 idk much about it or what all i need can some1 help me out?
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
You'll need some sort of gearbox adapter if you want to run a manual gearbox. Custom engine mounts, custom sump, custom bonnet to make it fit, lots of rewiring, custom headers to fit between the chassis rails and the crossmember.
There isn't much that is easy about it (same as any VH/VK swap into a Z32)
sidewaysvk56z32
Car: 1990 300ZX
thank man looks like i got a s*** load of work to do lolbut it will be worth it when im done
Return to “VH45DE / VK45DE / VK56DE Forum”
