SuperHatch »
https://forums.nicoclub.com/superhatch-u50790.html
Fri Jan 12, 2007 8:49 am
When disassembling both of my motors (92 and 94) I noticed something that puzzled me.
On the front end of the crankshaft, there are three gears installed before the lower timing cover goes on. Right Bank Timing Gear, Left Bank Timing Gear, Oil Pump Drive Gear.
All three of these gears have notches for the keyway on the crank. The Crank has two keyways, one about 15mm long closes to the block, and another 15mm long farthest from the block, and nothing in between.
When the Right and Left Bank Gears are installed, the keyway closest to the block is completely covered up, and there is no key for the oil pump drive gear to engage.
So that begs the question... how is it driven?? Both motors I disassembled allowed me to spin the pil pump freely by hand once the lower front cover was off.
Is the oil pump gear compressed between the Left Bank Gear and the Crank Pulley and that is how it is driven??? I find it strange that it is not directly driven off of the crank by a key if that is the case.
Am I missing something so obvious that I'm going to feel like and idiot when you tell me?
Thanks,Steve
