VH45DE Oil Pan Oil Level
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
qsiguy
Car: 1994 Infiniti Q45 Turbo
I'm trying to find out if anyone knows where on the oil pan the oil level is for a properly filled VH engine? Reason I'm asking is I'm contemplating drilling or poking/taping a hole in it for an oil return line and want to make sure it's above the oil level if I decide to do it.
If I do it I'd prefer to do it without removing the pan. I've seen a write up where they used gradually larger punches to avoid drilling, and then tapping the hole for an oil fitting. I just need to make sure the hole is above the oil level.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
From what I remember when i did chain guides on a Q you have about an inch of clearance.
See if you can find some pics of the front cover off without draining the oil. I would assume that oil would be somewhat less when the motor is on.
T45
Car: King Kong powered Z32
Why not just put the oil return into the valve cover?
RichZilla
Car: Y34 Nissan Gloria VQ30DET 12PSi & 20" rims
A turbo oil drain should always flow downhill. Or at least not uphill.
qsiguy
T45 wrote:Why not just put the oil return into the valve cover?
This is my plan, just humoring other options before pulling the valve cover to tap it.
RichZilla wrote:A turbo oil drain should always flow downhill. Or at least not uphill.
My turbo is a rear mount and I have a scavenge pump drawing the oil from the turbo and pushing it back up front to the motor. Not really an option to make it go downhill or even level since the turbo is so low.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
With a scavenge pump you don't have to worry about up, down, etc. so anywhere on the oil pan or even to the valve cover is fine.
Return to “VH45DE / VK45DE / VK56DE Forum”
