Hello all, I'm back,
I swapped the knock sensors with my spare VH45DE engine (which was working fine when pulled), and yes, the knock sensors on the one in my Datsun were cracked and pretty toast. The new knock sensors have not fixed the lack of power problem though. I may buy new knock sensors and harness soon.
if an O2 sensor is disconnected, does the ECU go into a creep mode? That's my next swap; but I think I have to pull the engine to get at them.
Yellow4g63 wrote: ↑Mon Oct 17, 2022 11:52 pm
wire in a consult port and buy the nissan data scan software and consult cable. You can check the codes on the ecu and see what the sensors are doing.
I'm familiar with the NisTune board, cable and software - but this seems like something else. I see a lot of posts from the past about it, but I can't seem to find a vendor.
