VH45DE in a Pathfinder?
JDMpathy
Car: 1998 nissan pathfinder
Hey everyone. I have a 98 Pathfinder with a vg33e. Its a nice truck but im looking for some more power. I've seen someone put a vh45 in their pathfinder. The only difference is that his was manual. I would like to keep mine automatic with the 4wd. Is this possible? Is the wiring possible?
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
I've seen it on NPORA but 1 he probably had an adapter for the manual trans to couple up to it, you probably need one for the auto too. Im just not sure if it would handle the power. Wiring is definetly possible cause he did it.
Alfredo24.pr
Car: 2002 NISMO Turbo Pathfinder LE
Well I do not think the auto transmission can handle that much horsepower judging from my experience
miamiheat3332
What are you doing to fix your trans slipping problem?
Alfredo24.pr
miamiheat3332 wrote:What are you doing to fix your trans slipping problem?
the work is almost done, I do not know exactly what has been done, but it will be ready on Tuesday. I will update when I now what was done to fix it.
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
What are you gonna do if your mechanic retires Alfredo??
Alfredo24.pr
CanuckQx4 wrote:What are you gonna do if your mechanic retires Alfredo??
lol well he started his own business about 3 years ago so I hope he does not retire soon. Plus the transmission mechanic is not the same one as the one that mounted my turbo(and will also install Haltech and brakes).
JDMpathy
im not too worried about the auto trans handling the power. Im planning on rebuilding it anyways. The only part that confuses me is the wiring.
like if i just get a q45 ecu and wire harness, wont i just have to splice the body harness onto the main harness?
