Vh45de conversion, manual (questions)
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Mattbacon
firstly, which flywheel bolts up2 a Vh45de
a Z32 300zx possibly??
cheers
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
300ZX flywheel and clutch will bolt on.
Mattbacon
oh sweet
so i take it that the flywheel is 316mm from outside of the teeth, side to side
and center studs are 65mm center to center (8 holes)
cheers for that, i will have a look about for one
can anybody else definatly confirm this? straight bolt up??(or have u got this setup in your car??) just before i rush out and spend my $$$
cheers guys
Modified by Mattbacon at 12:43 AM 7/28/2005
elwesso
2007 BMW M Coupe
The tranyn doesnt bolt up... You have to have an adapter plate made,but the flywheel will bolt up to the engine, and the clutch will bolt to the flywheel...
Mattbacon
thanks very much thats all i needed to know
i have allready got price for bellhousing chop
75USD$ so thats all good
cheers for ur help
Modified by Mattbacon at 9:24 PM 9/30/2005
Mattbacon
im just getting quote for exhaust
it will be running N/A for the moment, until the whole car is setup
what size wud be good for a basic N/A setup
i was thinking 2.5" twin down to a single 3"
the guy at the shop tells me he did a lexus V8 and did 2 1/4 twin into 2 1/2"
i was wanting to know whats worked for u guys??
cheers for any help
matt
elwesso
2007 BMW M Coupe
Most Q guys run 2 1/2in into a dual in dual out setup, basically like the factory has it.
Mattbacon
i havent ever seen a factory Q45 as they were never sold hereim sorry i diddnt quite follow ur explanation
so 2 1/4" from manifold, and to seperate 2 1/4" pipes running down either side of the car? is that how u were meaning?
my mechanic said that with V8's its better to run into 1 pipe to get a good V8 sound, otherwise wont sound very deep nice V8 soundthat was the reason i was planning on running into 1 larger pipe
thanks for any info u can providematt
Modified by Mattbacon at 9:23 PM 9/30/2005
elwesso
2007 BMW M Coupe
What im saying is it will be dual all the way until the rear muffler, in that it will go into a dual in, dual out single muffler..... It will look and sound real nice...
Be sure to hook yourself up with a nice X pipe or something cool like that!
Mattbacon
thanks very much elwesso
does anybody here run into a single pipe for their exhaust (if so what sizes)?
i just wana grab as many opinions as i can so i can make the best decision
thanks guys
EDIT also what clutches do the manual guys here run??ive been getting sum prices, and approx was about 750$ for twin plate (that was for an EVO mitsi, but shud be similar approx)and i think i mite just get a 3 or 4 puck clutch instead, i think one with decent pressure plate shud be enuf for the V8, hope so anyways, (dont wana spend 750$ on clutch at this stage!!!!)
Modified by Mattbacon at 9:21 PM 9/30/2005
Mattbacon
elwesso wrote:300ZX flywheel and clutch will bolt on.
thanks again,
i found a 300ZX flywheel new, (bloody EXPENSIVE!!)and like u said, same 8stud hole, same center hole ect
another thing
does the VH45 starter motor ring gear fit straight onto Z32 300ZX flywheel?
or are there sum required modifications??
cheers
elwesso
2007 BMW M Coupe
Mattbacon wrote:thanks again,
another thing
cheers
You juts want to use the 300ZX starter, as the Q45 starter bolts to the engine, and the Z32 starter bolts to the transmission..
Mattbacon
oh right
im using the Vh45 bellhousing stilland a skyline gearbox chopped onto it
so i may have to cut a whole in the top of the bellhousing to fit the 300ZX starter motor by the sounds??
hmm, sounds like gona be abit of a mission?
do u use 300ZX gearbox with adapter plate? or shopped bellhousing?
thanks again
elwesso
2007 BMW M Coupe
ID use a 300ZX transmission with the adapter plate..... youll also need a spacer, but everything else is bolt on, factory-esque.
Mattbacon
arrrghhhh
haha
tru
i allready got another box, and chopped bell-housingso gota use that
umm
starter motor fuk hope i dont have to push start it!!!
i think i will get a flywheel made to EXCACT same dimension as facorty flex plate so can use the VH45 starter
cos 300zx flywheel bit different outside size, and wont fit to ring gear
hope that works, otherwise mite be abit of a nightmare :S
Ezekial
Car: 2001 Nissan 200SX S15
Mattbacon wrote:arrrghhhh
haha
tru
umm
Sell your skyline gearbox and get a 300zx manual gearbox!
Cheaper and i believe just as strong ??
Then get the adapter plate made up and get it made x2 ... and send one of them to me in OZ!
Money awaits my NZ friend
Mattbacon
im gona stick with the 5spd i got,
looks like im gona have to mount the engine abit further foward than earlier planned
and now get a custom drive shaft as well
jrsink
any progress?
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
jrsink wrote:any progress?
I've been in touch with Matt, he's trying to sell his setup, or swap it for a turbo Laurel. A little part of me died inside when I heard that.
Return to “VH45DE / VK45DE / VK56DE Forum”
