Darinz - What system are you running to interface to the stock ECU? Bikirom?
darinz wrote:To do this I think I'll need bigger injectors as the tuner thinks he'll need a lot more fuel to control detonation.
While needing the correct amount of fuel is essential, make sure your tuner does not forget about ignition timing. I am a big proponent of what Klaus Allmendinger has to say in his article (
http://innovatemotorsports.com/resources/rich.php).
There tend to be two primary schools of thought for tuning a forced induction engine:
A.) Set air/fuel ratios """safe""" to a rich region around 10.5 - 11.0 on 93 octane and run relatively higher ignition timing.
B.) Set air/fuel ratios to the region where gasoline produces the most power between 12.5:1 - 13.5:1 (less than 1% difference in max power in this region, so I choose the richer AFR of 12.5), and retard ignition timing slightly.
Per Klaus' article, I tend to go with option B. As it makes most efficient use of the fuel, and retards the flame front by retarding the ignition timing, as opposed to retarding it by an overly rich air/fuel ratio.
What I'm getting at is: You do not necessarilly need excessively rich air/fuel ratios to control detonation (11.5 or richer). You will be able to still control detonation very well with a reasonable air/fuel ratio (12.0 - 12.5) and retarding the ignition timing.
You may already know this stuff, but I figured I'd take the opportunity to post about it anyway.
