VH45DE bellhousing to engine bolt diameter.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
Does anyone know what the bolt diameter is for the VH45DE bellhousing to engine bolts? I know the thread pitch is 1.5 using a metric thread gauge. I don't have a tap large enough to fit into the back of the engine that I bought to use for measuring purposes. The biggest tap I have is 12mm.
Thanks, Matt
mattd1979
Did they change the bolt size in 1994 to the bolts that mount the transmission to the engine? I ask because when I was back at the yard the other day, I grabbed one of the bolts from the car I pulled the engine from so I had something to size. I found that the bolt will not fit through the hole in the engine stand bracket that you mount to the engine. The stand I am using is the same one that I had my other engine on a few years ago.
450zxsd
Car: 1991 300z h45de
My 1990 vh is a 14 mm
mattd1979
I ended up drilling the holes larger in the stand in order to use the bolts to hold the engine to it. I still don't know if they increased the size of the bolts in the later VH45s.
Return to “VH45DE / VK45DE / VK56DE Forum”
