RichZilla »
https://forums.nicoclub.com/richzilla-u71063.html
Thu Nov 08, 2007 12:26 am
Not a big drama, but anyway. Keep in mind that my speedo is still not connected, therefore ECU is not getting speed signal from dash.
Whenever I lift off the throttle, the auto seems to neutralise. As soon as I push the accelerator in a bit, it goes back into gear. It also seems to be taking off in second gear. If I absolutely mash it on take off, it'll get to about 3500rpm before downshifting into first. Makes for good skidmarks, but not much else. I can't manually put the auto into a lower gear because the merc shifter has different spacing to the Q. I.E Neutral is where drive is, 2 and 1 are drive and that's it. Need to make a shorter selector bracket off the trans to solve that prob.
Anyone have any ideas?
