vh45de adapter plates?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
craig98
Car: 96 jetta
i found the two main comapnie that people are using for these kind of swaps. but i keep hearing mixxed reveiws about each. was wantin to know if anybody on here has one of these companies adapter plates and what you thnik about them. with the mazworx adapter what do you have to modify on your bellhousing for it to work?
http://www.mazworx.com/product/drivetra ... vg-adapter
http://www.xcessivemanufacturing.com/ON ... =4&pid=195
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
I used Mazworx adapter and I am more than satisfied. If you buy the Mazworx adapter, you send them your bellhousing and they machine out a section the thickness of the adapter so that the adapter bolted to the transmission is the exact length of the transmission's stock bellhousing.
craig98
Car: 96 jetta
speedeast wrote:I used Mazworx adapter and I am more than satisfied. If you buy the Mazworx adapter, you send them your bellhousing and they machine out a section the thickness of the adapter so that the adapter bolted to the transmission is the exact length of the transmission's stock bellhousing.
o ok. does the trans mount to anything besides the adapter? like is there any brackets on the bottom of the trans?
speedeast
no, but that's how most cars are. It's only one bolt fewer than it would be bolting to a VG, but the bolts are twice the girth. There is another brackets that the OEM uses that can be modified to fit, but I didn't use it.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
vh45-to-vg30-adapter-plates-now-available-t500431.html
No modifying bellhousing, and can use all factory parts to make it work properly. Used this plate in my setup for the last 45k miles or so on my Q, and still going strong!
craig98
Car: 96 jetta
elwesso wrote:vh45-to-vg30-adapter-plates-now-available-t500431.html
im very interested in oyur adaprter plate. just have a one questions. which starter do you use? the factory vh45 starter or the z32 starter? i would much rather spwnd what your askin for one rather then those other copanies i found.
speedeast
Those others are pretty expensive for a piece of CNC machined metal... elwesso has respectable products. I'm almost positive you have to use the Z32 Starter.
Wes, did you have to space the flywheel?
elwesso
2007 BMW M Coupe
Yes regardless of what plate you use you will use a Z32 starter.
My plate uses the factory spacer behind the VH flex plate.
craig98
Car: 96 jetta
elwesso wrote:Yes regardless of what plate you use you will use a Z32 starter.
sweet well once i get my car sold this week hopefully il be getting ahold of you about one of your adapter plates.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
My plates will be going into production in about 3 weeks. They will hlf moon style kind of how one of the others on the market currently is. Our's too will require bell housing machining.
boatdude13
Car: 1995 Jeep Cherokee
1977 Datsun 280Z
ooo exciting drftbld
elwesso
2007 BMW M Coupe
DRFTBLD- any particular reason you went with the mazworx style vs. anything else? Just because of the spacer issue?
DRFTBLD
91 S13 Tester
08 Ford Focus
THe spacer was the biggest reason behind that half moon style. Howeever when we did some load tests we got a little 'twisting' on the full circle style. Not saying yours and Xccessive's isn't good and not recommended, Just the one we created didn't have the same strength as what a half moon style did when under high load. We have ben testing and building based on the needs of our build, the VH45DETT set up and the HP it is going under. So with that in mind the spacer needed on the flywheel along with the location of the trans further back on a full circle adapter (every inch... or less... counts) was what made us go with the half moon.
Now that being said it does tick me off that all the Z32 transmission's will start to be hard to find in unmodified state if we are all having our bellhousings modified to fit these adapters.
Moreover - we are also going t be releaseing a template which you can take to any machine shop (or do it yourself) and have them machine down the bellhousing so that you can reduce costs and you don't need to ship the bellhousing anywhere.
Return to “VH45DE / VK45DE / VK56DE Forum”
