Running a bit rich on the left bank are we? Great project
Are you running the stock ECU on the VG30 right now? Any plans to run aftermarket on the VH45? Also, about the rear aero. That was a good idea, but I was also researching making an active aero controller to automatically increase the drag. Sorry if this goes off topic a bit. If it does, we can start a new thread. Also I don't know how good you are with electronics, so stop me if I am going crazy.
Here's what I was thinking for the controller:You either need to feed in an existing speed signal, or it needs its own accelerometer. Optionally it can also have a brake override wire (so if you are hard on the brake for some predetermined time, it just folds against the wind to slow you down).It should obviously have an auto mode but still have a manual mode. When in auto mode:
- Increase pitch when braking/decelerating more than 1.0s or over some threshold (maybe configurable)- Change the angle of attack after you exit a turn or are accelerating- Have a dead band so that the thing is not switching constantly when you are near the threshold and thus damaging the actuators.
There are some trade-offs to having a built-in accelerometer ('+' for pro, '-' for con):+ the unit will be universal and will work in any car without custom speedometer detection circuitry+ will not require any custom calibration based on different rear ratios, tire sizes, etc...+ It will work irrespective of wheelspin (speed sensor would read higher since it has no idea that the power is not being transmitted to the ground)
- Could lose sync without a speed signal: accelerometers record acceleration not speed, so for speed calculations, you need to integrate acceleration. This coupled with the accelerometer error and not knowing the initial speed can cause integral runoff error.- Accelerometers can be a bit pricey, luckily you only really need a one axis or possibly two axis (if you really want to be precise when going into a nasty turn).- A one axis sensor will require mounting the sensor in a specific orientation (front to back, but you may turn the circuit board how ever you want providing that is met). A two axis sensor will require you to be more rigorous, and mount it in a specific way front to back and side to side (think about what happens to East West when you flip a compass upside down, same concept). Otherwise, you need some configurable way to define what is forward and backward (and thus also left/right on a two axis).
Or... you can win the lottery and buy one of these starting at $4k.
http://aeromotions.com/products/
