elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Jun 22, 2006 2:15 am
basically this is how it works... The CAS has the 4 pin plug... Sigal 1 is the 90* signals, signal 2 is the 360* signals... the other 2 are obvious.
If for some reason the main crank angle sensor dies, the sub crank angle sensor is still operational... Its a seperate plug for essentially the same sensor, except it only gives the 90* pulses.....
Basically you dont have to have the other one hooked up. Its a fail-safe part so that if the main cas goes bad (they hardly ever do), granny could still drive her Q to the dealer to get fixed... If the main CAS is working properly, the other connector is not even being used.
on the later VH45s (94+) they had a single (7 pin) plug... The cas no longer says NISSAN on it, rather hitachi if memory serves... It has the roundish connector...
