By that logic I should just go out and drop a SBC 350 into it. I want a non-US V8 for the same reason that I drive a Z instead of a 510, 951, or RX-7; why I drive something with a stick instead of an auto; why I DRIVE rather than walk, and why I intentionally got a car with no power anything, no AC, and a bad heater even though I DD it in weather that ranges from below freezing to 120+. Because I *want* to. I know that a VH is considerably more work than most other engine swaps. I know that I could make 400whp with my current block (swap the mikunis for ITBs, 2mm HG, P90 head, turbo, turbo exhaust, plenum, FMIC, piping, and a in tank fuel pump would be all I need basically). I wasn't asking "How can I make this much power period", I was asking "Of these two V8 platforms, which would you prefer as a starting point".redhat-z wrote:Just my $.02, doing a VH swap is way more involved than most people think. In your case, I would just get a P90 head with mechanical lifters, single turbo, Megasquirt and be done with it. You should still be able to get 400 - 475 out of that. Every VH swap is ultra stupid custom, sucks up all free time and money, and ends up being worth it if it works. Then you can say you have a Nissan V8 in your car that makes around 310 hp bone stock with high miles. I just would not suggest it if you can get the same power out of your current engine. That's like having an R32 Skyline with an RB26DETT and swapping it for a VQ35DET. Why, why, why?
I believe the VK is a little lighter, thinner casting block which makes it a little weaker? I read that some where, but the Nizpro in Victoria Australia are making BIG HP out of them so they cant be too badIf you ask me i would go VH as they seem to be stronger, and preferably go twin turbo, that would be SICK in your ZPanzerAce wrote:
*deep breath*
Some other observations:1) I can't meet either of my power goals with an L series and still have it remotely drivable on the street. 600whp is *possible*, but on the 91 octane that I have to deal with it wouldn't be enjoyable.2) 20yr old engine with 310hp stock vs. 40yr old engine with 140hp...I'll take newer and double the power.3) Last I heard, people were swapping RBs out in favor of VQ and even VG engines for the greater displacement.
*another deep breath*.
Sorry man, but posts like that p*ss me off. If I had asked what the easiest way to make that power was, then that post would have been awesome, but that wasn't what I asked...
If you've got an opinion on VH vs. VK, I'd love to hear it though
Is the VH really stronger? I know that car companies make some stupid decisions pretty often, but did they really make a newer block...weaker?
and assumed you thought you needed a VH/VK to make that kind of power. No need to get hostile.PanzerAce wrote:
My goals are: 400 or 600whp (400 if NA, 600 if boosted)Daily Driver reliability (assuming I do my part with the build)Stick shifta higher redline (say, 8k)
Why have I never seen that first manifold you linked to? Anyone ever looked into it?Bart wrote:I have also read stroking the crank (or VH45 crank) and boring can get you close to 6 liters.
http://www.kinsler.com/manifol...n.htmh ... im...a%3DN
http://images.google.com.au/im...a%3DN
ITBs for a VH45??? Do my eyes deceive me? *sigh* too bad they'd never fit under a stock Z32 hood.Bart wrote:I have also read stroking the crank (or VH45 crank) and boring can get you close to 6 liters.
Thats been around forever, i called and spoke to kinsler like 1.5 years ago in reference to that set.. They where a one off for a guy in australia who had one of the indy vh45 motors, point in case tthey had already recieved 20 plus calls and interest and determined that they would not fit the regular us spec or jdm vh45 due to the fact that the bolt patterns where different.DJ Raijin wrote:
Believe me, I'm well aware of how build costs and times go. There's a reason I'll be DDing something else while this is in the works.gs14racer wrote:All i can add to this is assuming your doing the work yourself its gonna cost a lot more than you think it is.
and of course the fact that there is virtually zero aftermarket support for this engine.
Cool, I'll track that thread down. Normally I wouldn't be worried about stock internals, but add that to a lighter block and no real improvements anywhere, VK doesn't seem like a very good idea.Mettler wrote:If you've got a bit of money to spend, then get a VH45 and trick up the internals and valvetrain.
There's a thread on here somewhere already comparing the VK internals to the VH, and they are significantly less meaty in the VK... and the block is lighter etc.
The VK has some small improvements... titanium valves etc, but the porting appears to be no better.
So really, it becomes an easy choice when you consider that in standard form, the VH is stronger and cheaper with the same performance potential.
if you're looking for a vh45, lots of pick and pulls up here have Q45s in abundance for you to get them out of for only $120-200 (varies on what you keep on the motor).PanzerAce wrote:
Now to go find a block. Any recomendations, or is it easiest to just grab an Infiniti for cheap and yank the block out of it?
No that is incorrect. There is a post in this section about this.ken in az wrote:Oh, and I forgot to add that I am pretty sure that the Frontier 6sp trans will bolt up to a VK series engine so the use of an adapterplate might not be necessary.
Can someone confirm?
I'd be interested in the info that you come up with. Your pictures also make me *so* damn glad that I'll be ditching all the smog stuff, computers, etc.marksport wrote: [bunch o' pics]
I think the VH might be a stronger motor for forced induction with stock internals as it has the reinforcement girdle under the main caps. For n/a the Vk would be better with the lighter valvetrain. I am in the process of doing a side by side comparison of these two motors. The VK is simpler and has less parts. The VH is a nightmare to remove the manifold and just as bad once the upper is off as you can see the big mess under the plenum. Pretty much every hose there was brittle and broke off.
I just finished removing the lower manifold, power steering pump and few other brackets and the oil pans. The girdle from the VH45 will fit the VK45 as long as you bring over the studs or get longer bolts. I'll have to find the wall thickness as it was in the SAE papers I got. I'll measure the crankcase width next chance I get.PanzerAce wrote:
Are you going to be measuring wall thicknesses, etc? TBH, it's starting to sound like which engine I use is dependent on if I want to build a high strung NA motor or a FI motor.
One thing I'd really be interested in if you can manage it is a bunch of specs on the dimensions of the engines, especially the width down at the crank case (where it looks like the VH has an AC unit or something similar bolted onto it), since that is likely where I'll be attaching my SC unit(s), since higher I'd run into issues with the exhaust and then the wheel arches..
Cool, thanks man. Dimensions on the engine and engine bay might end up dictating NA vs. boosted for me on this build (though seeing a recent thread on HBZ about a 330whp 3.1 liter L series makes me not so worried about that)marksport wrote:
