marksport »
https://forums.nicoclub.com/marksport-u11501.html
Mon Jul 30, 2007 9:53 am
I have taken apart my project motor and have done the comparison of the VH45 and the VK45 Rods and pistons.
The piston on the left is the VK45, on the right is the VH45. VK45 has shorter skirts and the distance between the rings on the VK45 is less. There is more distance from the oil ring to the pin.
The rods are very similar. You can kind of see the VH45 rod around the VK45 part sitting on top of it.The stem of the VH45 rod is just over 22mm thick vs the VK45 rod at just under 20mm, a difference of over 2mm. The radius of the rod where the stem and the big end meet is also wider on the VH45. The thickness, pin diameter and big end diameter is the same.
The VK45 rings on the left, VH45 on the right.VH45 rings are thicker and wider.
Overall, the VH45 is a stronger motor. Is it superior? I don't think I'd go that far, but booth motors are fairly similar in design and quite capable.
Modified by marksport at 8:03 AM 7/31/2007
Modified by marksport at 8:06 AM 7/31/2007
