VH45 VK45 comparison
marksport
I did a comparison on the rods and pistons of the two.
zerothread/268439
zerothread/269294
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And let me thank you for being the first to post that with pictures.
One question I had was a comparison between the big end rod area.
marksport
There are pics of the big end. The rod caps are the same and even interchangable. The VH45 has thicker base where the radius of the big end meets the stem, along with the stem being just over 2mm thicker.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
So the bearings are the same?
marksport
maxnix wrote:So the bearings are the same?
Yes, the bearings are the same. I took the bearings off the original rods and inserted them onto the VH45 rods so that I could install the VH45 rods and pistons into the VK45 motor. The crank turned smoothly and the pistons cleared the crank.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
This will be an interesting build indeed.
draivar
Car: 1991 Q45
pics in both posts still aren't working....at least for me.
szh
Car: 2018 Tesla Model 3.
draivar wrote:pics in both posts still aren't working....at least for me.
Jesda posted in one of those threads that he is moving something and the pictures will be back later ...
Z
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
So are you making what we used to call a stroker?
marksport
AlabamaDan wrote:So are you making what we used to call a stroker?
Nope, just a mild supercharged motor.
