gdz1la »
https://forums.nicoclub.com/gdz1la-u42260.html
Mon Nov 13, 2006 11:54 am
hydrallicing it out is a messy waste of time there is no air pocket directly behind the bush, it would be like pushing a car sideways. i just drilled it on both sides then wacked it with a chisel and pulled it out.the bush is in but now i have another problemthe crank isnt deep enough for the input shaft, i wont engage on the 1st of the 3 clutch plates enough, it only on the fist mm of it, as it bottoms out at the back of crank,im now stucki see i have optionsmill shaft down about 15mm so it fits in v8 engages all 3 plates and lines up starter, and proceed with welding v8 belhousing to vg one..
or switch to a spacer/adaptor, i cant afford the one on here but could make my own lots cheaper, and run extra long bolts which im worried about doing.. this will also upset the shifter location, and maybee my driveshaft
any ideas guys
