Ok, got the actual specs for the stage 2 camshafts:
ADV. Duration @ .006" Lobe Lift = 258°
Duration @ .050" Lobe Lift = 189°
Camshaft Lobe Lift = .247"
Valve Lift: .395"
Now if I were to use duration @ .002" lobe lift the degrees would increase to 298° So lets say the 272 camshafts had an advertised duration @ .005" or even .004". You can see how much difference there is in duration between my camshafts at .002" and .006".
I had a set of camshafts hardness tested and then reground to the MAX! These would be my stage three, but first I need to test them out to make sure they can be used with VCT.
ADV. Duration @ .006" Lobe Lift = 266°
Duration @ .050" Lobe Lift = 210°
Camshaft Lobe Lift = .232"
Valve Lift: .371"
So you can see what happens when you max out your duration, you start to lose valve lift, but your valves are open that much longer, which worries me with the VCT. These cams are going to have a nasty idle
These camshafts are available for $840.00 Shipped. They are not advertised on the website yet, but you can purchase these.
