VH45 Turbo build - Need advice
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
LXJET
Hi All, I have spent 4 or 5 hours researching this and cannot seem to find an actual list of parts used in a vh45det turbo / twin turbo. I'm writing a project plan and looking for required parts to go buy. I would love to know what others are using which is tested and proven parts in their vh45 turbos.
I am looking for around 650HP with a single or twin turbo setup. I am still researching the best setup, leaning towards a single at the moment.
Looking for the following plus any other, valve springs, valves, rods, pistons, what compression to run, turbos and wastegates to use (going to use external gates), Injectors, cams ( This is a big one, would love specs but not many people willing to give these out. Transmission, stall converter (looking at a 2 speed power glide) What kind of porting to go, inlet and outlet manifolds are sorted but still willing to listen to advice.
Thanks in advance. Email below for anyone who wishes to use it. Looking forward to any answers.
If anyone is in Melbourne Australia would love to hear from you also.
Craig
Protune Racing
Car: S13, 260z, Q45, 300zx
Hey Craig,
I have access to most of the things you are looking for. We were building a twin turbo vh45 with new pistons, rods, cams, springs, copper head gasket..etc
Our setup would defiantly have you covered for power, as we were hoping for close to 1000hp and a high rev limit. :biggrin:
I would defiantly love to talk.
Cheers
James
LXJET
HI James, Thank you for your reply. Your parts sound like what I am after. My budget isnt massive for internals so im not sure if it would all cost too much but I am definitely keen. My email is [email protected] if you would like to email.
If you could please let me know an exact list of everything you have, exact specs and any other information it would be hugely appreciated!
Where abouts are you located? I am in Melbourne.
Also wondering why you didnt go ahead with your project.
Kind Regards,
Craig
Protune Racing
Craig i will send you a list shortly with some pictures. By the way do you happen to be building the green s14 with the roll cage i saw a picture of a while back.
James
LXJET
Im building an LX torana, in undercoat at the moment and not on the road as yet.. Will make a post when its nearly done :)
jalinar450
Car: 2006 maxima
s13 hatch spot welded rolling chassis for sale
1995 450sx in the works
LXJET
That is awesome, thanks a heap Jalinar.. Will email them and hopefully get a bit of help.
Regards,
Craig
Protune Racing
Email Sent Craig :)
Kind regards,
James
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Protune Racing wrote:Email Sent Craig :)
Kind regards,
James
Can you contact me with the same info for this build?
[email protected]
Thanks
Ron
giantumbi
Car: 94 q45
hi there if i could possibly get some info too im still debating between this kind of set up or the supercharger roots type in another forum that is around 4500 dollar setup............. [email protected]
Return to “VH45DE / VK45DE / VK56DE Forum”
