vh45 throttle body
bentandbuzzin
Car: 1992 300zx n/a manual 2+0
i want to know if there are 2 types of throttle bodies that were used on the vh45 engine. I search the salvage yards and every q45 i come across has a throttle body that has 2 butterfly valves. One in the front and one in the back of the throttle body. It also looks as if one is operated by a cable and the other is operated by a motor on the side. When i research for the vh45 swap the guys who do the swap have a vh45 that doesn't have this type of throttle body. Can anyone help me?
Q45tech
ottle plate is used by OPTIONAL traction control system to choke off air flow when rear tires spin. Since rear brakes would soon overheat in seconds without a reduction in engine power.
Always use the correct components to match option packages.
